How to Send and Schedule Your Content Using Canva and Nuelink.
You can now use the Canva x Nuelink integration to create and schedule your content seamlessly. You can both:
  • Send your Canva designs to be scheduled on Nuelink
  • Send your Nuelink media to edit on Canva
And then schedule on Nuelink to post to all your socials. In this guide, we will provide you with a clear, step-by-step walkthrough on how to send and schedule your content with Canva and Nuelink.
First, make sure you connect your Canva account to Nuelink here.
In this Guide:
  1. Send Media From Nuelink to Canva.
  2. Send Designs From Canva to Nuelink.
  3. FAQs and Troubleshooting.
You can send your Media from Nuelink to Canva, whether it’s an image or a video. Make sure you link your Nuelink app to Canva before you continue.
  1. Log in to your Nuelink account and click ‘Create Post.’
Click on Create Post
  1. Upload your media from your device by clicking on ‘Upload Image(s)’ or ‘Upload Video(s).’ Or import from your Media Library.
Click on highlight
  1. Click on the ‘Send to Canva’ icon. You can also access that using your Nuelink Media Library.
Click on image
  1. Create a new Canva design and click on the Nuelink app at the bottom left side of the menu.
Click on Nuelink
  1. Select your brand.
Click on Casa Lydia Store
  1. Select your media to upload and edit.
  1. When you are done editing, click on ‘Save to Nuelink.’
Click on Save to Nuelink
  1. Select your media file(s) type and pages to import to Nuelink.
Click on Export
  1. Confirm by clicking ’Export.’
Click on Export
  1. Wait a few seconds for the media to be exported, then return to your Nuelink post.
Click on Please wait, this can take a few moments.
  1. Click on ‘Media Library’ from the Post Editor.
Click on Media library
  1. Select your media files, and click ‘Add Selected File(s).’
Click on Add Selected File(s)
  1. Now finish editing your post and schedule it as you see fit.
Click on Add to Queue
You can send your designs from Canve to Nuelink, whether it’s image(s), carousel(s), or video(s). Make sure you have linked your Nuelink app to Canva before you continue.
  1. Once your Canva design is ready to be scheduled, click on the Nuelink app at the bottom of the left menu.
Click on Nuelink
  1. Select a brand to send your design to.
  1. Click ‘Save to Nuelink.’
  1. Select your media file type and pages.
Click on MP4 Video…
  1. Confirm by clicking on ‘Export.’
Click on Export
  1. Wait a few moments for your design to be exported, then head to your Nuelink account.
  1. Click on ‘Create Post.’
  1. Click on ‘Media Library.’
  1. Select your design(s) and click on ‘Add Selected File(s)’
  1. Finish editing your media and post elements, then schedule your post.
What type of media can I send to Canva?
You can send only an image or video media file from Nuelink to Canva; just make sure you send 1 media file at a time.
What type of designs can I send from Canva to  Nuelink?
You can send all types of posts, images (s), videos (s), carousels (s), and story(s, just make sure to wait a few moments for your media to be added to Nuelink.
Where do I find my imported media from Nuelink on Canva?
Search for Nuelink in the apps section on Canva, or start a new design and click on Nuelink in the left side menu, then select the brand you imported your designs from, and you will find your designs after they load.
Where do I find my imported designs from Canva on Nuelink?
You will find your Canva designs in the Media Library of Nuelink of the brand you saved your files to.
Do I need to have a Canva Pro account to schedule Canva designs using Nuelink?
No Canva subscription is needed to schedule your designs using the Nuelink App; you can link your free Canva account, and you will be good to schedule all types of posts and content.
