How to Convert Carousel to PDF/Document Posts for LinkedIn on Nuelink
Make sure you're signed in to your Nuelink account and that your LinkedIn account(s) and page(s) are connected. If not, you can connect by following these steps. Now, let's walk through the process of creating a LinkedIn Document post.
⚠️Keep in mind that document format posts are only supported by LinkedIn Profiles and LinkedIn Company Pages.
Guide Content:
What You Must Know About LinkedIn PDF Posts.
What are LinkedIn Posts Requirements?
How do you turn a carousel post into a PDF post for LinkedIn?
LinkedIn Document Post FAQ & Troubleshooting:
What is a Document/PDF Post?
A LinkedIn multi-image post lets users share a PDF or PowerPoint file as a swipeable carousel on the feed. Each document page appears as one "image." Unlike other platforms, LinkedIn carousel Files are a maximum of 10 pages and adjust to different sizes and specifications for a high-quality look.
Why make a LinkedIn Document/PDF Carousel Post?
LinkedIn document carousel posts are visually engaging and interactive. They allow users to share step-by-step guides, statistics, infographics, and other informative content that the audience might want to save for later. These posts are powerful tools for driving engagement, boosting brand awareness, and building community on the platform.
Media Amount
Media Type
Media Size
Media Format
LinkedIn
10 images max,
1 video,
10+ Document pages
Images, Videos,
PDFs
12 MB max
  • 1080 x 1350 px (recommended)
  • 1280 x 720 px
  • 6012 x 6012 px (max)
On Nuelink, you can simply schedule all types of posts supported on LinkedIn, if you want to know how to schedule a PDF post you can read this article, or you can follow this guide to learn how Nuelink can convert your images to PDF carousels in a simple click:
  1. Click on Create Post at the top of the navigation bar:
  1. Select “Post” as your content type, and select your collection and social media accounts including your LinkedIn profile or company page:
  1. Upload your images by clicking on the following options, Upload Image, or Media Library:
    Note: Only images can be converted to PDF carousels for LinkedIn.
  1. Here’s a preview of how the image carousel will look on LinkedIn, check the next step to turn it into a PDF carousel:
  1. Turn on “Convert Pictures to a PDF Carousel for LinkedIn” to automatically convert the images to a document carousel only for LinkedIn:
  1. Check the preview of how the PDF carousel will appear on the LinkedIn app:
  1. Edit the document name if needed by clicking on the “Change file name” button:
  1. Add your caption, enhance it with the NueAI assistant, and set up all your post elements:
  1. Schedule your post by adding it to the posting queue, or post it immediately, or as you want:
  1. Finally, this is how a posted LinkedIn PDF post will look on the LinkedIn app, you can click the arrow(s) to scroll through it:
Why did my Multi Image not post after I scheduled it?
If you encounter any publishing errors it is most likely due to the video duration, format, or size.
Please make sure your posts meet each Platform's requirements.
Can I create a one-off post?
Currently, all your posts must be created in a collection. However, Nuelink will soon allow you to create one-off posts.
What is the maximum number of pages for the LinkedIn file upload?
Currently, LinkedIn only allows over 10 pages per document, however we can only convert 10 images maximum to a PDF post.
Can I bulk-upload carousels and multi-image and document posts in Nuelink?
Yes, we recently added the ability to upload multiple images and videos when bulk uploading posts. This is how you can bulk upload your posts.
Can I change the time of posting for a post that is already in the Queue?
Luckily, you can. Click on Edit at the bottom of the post then click on Schedule. You can then select an exact date for your post
LinkedIn posting error is caused by the restricted account.
It looks like your LinkedIn account has been restricted for some reason. There are many activities that may lead to your account being restricted from posting by LinkedIn, here are some examples:
  • An unusually large number of page views from the account.
  • The name used in the account profile is in violation of the LinkedIn User Agreement.
  • Inappropriate or illegal activity on the account.
  • A history of repetitive abusive behavior on the account.
  • The account may have been compromised.
You can check this link from LinkedIn for more details: https://www.linkedin.com/help/linkedin/answer/a1340522
