How to Connect Box to Nuelink
In this step-by-step guide, we will walk you through the steps of connecting your Box account to your media library on Nuelink. Make sure you are logged in to your Nuelink account before we continue.
Contents of this Guide:
Upload Media Files From Box to Nuelink Media Library
Upload Box Media on Post Editor
Media Library FAQs and Troubleshooting:
About Box.
What is Box?
Box is an online cloud file sharing and content management service website. It provides a single place where you can store files in the cloud, share them with others, sync them across devices, and work together on projects. You can easily share files and folders and work together with people both inside and outside your group, and access them from any device.
Why link Box to Nuelink?
When you connect your Box to your Nuelink account, you can quickly get all your pictures and videos from Box and add them to your posts without any hassle.
Connect Box to Nuelink.
Let’s get started:
Click on “Media Library” at the bottom of the left menu.
Go to the media library section to connect your Box to Nuelink.
Click “Settings”.
Go to the settings of your media library.
Click the “Connect” next to ‘Box’.
Tap “Connect” to Box.
Click “Grant access to Box”.
Tap “Grant access” to allow Nuelink to connect to your Box account.
📝Note: Please keep in mind that we will never import or upload anything without your permission.
Box connected successfully.
You will find your Box successfully connected to Nuelink.
Click “Upload Media” and select “Box”.
To upload your media to Nuelink, tap “Upload Media” at the top right corner, choose the “Box” option on the menu.
Select Media.
📝 You can import images and videos from Box.
Click “Upload Selected Files”.
Once you select your media files, confirm by clicking “Upload”.
Click “Actions”.
Once your media(s) is uploaded you will find it in your media library. You can click actions to download a file to your device, Edit your file, or delete it from your media library.
On Create Post, click “Media Library” then, click “Box”.
If you are creating a post, and need to import a file from your Box account, click Media Library then choose Box.
Select your media(s).
Choose any media file on your Box account.
Media on post preview.
Your file will be uploaded successfully, and you can check how it will appear on the post preview to the right.
Disconnect Box From Nuelink
Navigate to Media Library Settings.
Click on “Disconnect” next to Box to disconnect your Box account from Nuelink.
What type of files can I upload using Box?
You can import images (JPEG, JPG, PNG, GIF) and videos (MP4, MOV) only.
Can I upload carousels using Box?
No, if you follow the steps in the Box guide, you can select and import only image and video files from Box.
Can I import media for CSV Bulk Imports using Box?
You can use the links from Box to import images and videos. Just make sure all your links are public.
