Publishing and Scheduling FAQs
Why did my post fail to publish?
Failed posts usually come from one of five causes. The social account may need to be reconnected, the media format may not be supported by that network, the post may violate a platform-specific rule, the queue item may be incomplete, or the channel may have been removed from the collection or queue. Open the failed post, read the exact error shown on it, reconnect the channel if prompted, and review the media specs for that network before retrying.
Why are my posts not publishing even though they are in the queue?
Queued posts only publish when three things are true: the channel is connected, the post is still valid for the target network, and the schedule slot is active. Open the Queue tab to see the next publish time for each post. If a post is marked Skipped or Failed, open it to see why and retry once the cause is fixed.
Why can't I add more posts to my queue today?
Every plan comes with its own queue size, daily upload cap, and per-batch bulk limit. These are three separate limits. For example, if your plan allows 100 queued posts and you already have 100 scheduled, you'll need some posts to publish or delete a few drafts before adding more. You can see your current usage on your plan page.
Why did my Instagram Trial Reel publish as a public Reel?
Instagram Trial Reels rely on an option that third-party tools can't always control through the Instagram API. If Nuelink does not fully support Trial Reels for your account(under 200 followers), the post may publish as a regular Reel.
Why is Best Posting Times not working?
Best Posting Times needs enough posting and engagement history before it can suggest time slots. Very new accounts, or channels with only a few posts, won't have enough data yet. Keep publishing consistently and check back after two to three weeks. The feature works on the same channels where Nuelink provides analytics.
Why did only some channels publish while others didn't?
Each network validates and publishes on its own. One channel can post successfully while another fails because of different account permissions, media requirements, or network-side rules. Open the post and check the channel-by-channel status panel to see which network failed and why.
My post shows "Failed" with no clear error.
Open the failed post inside the queue and click the channel name to see the network-specific reason. Nine times out of ten, this points to a reconnection issue, a media format problem, or a caption length limit. Fix the flagged item and click Retry.
My post was published on Instagram but not on LinkedIn (or vice versa).
Multi-channel posts publish independently. Check the post's status panel, fix the specific channel that failed (reconnect, edit the caption, or swap the media), then retry just that channel.
My queue looks empty even though I scheduled posts.
Make sure you're in the right brand and collection. Posts only show in the queue of the collection they belong to. You can also use the All Posts view to confirm your scheduled posts are still there.
Nuelink shows "Channel Inactive" next to one of my posts.
Go to Channels, reconnect the flagged account, and grant all requested permissions. Your queued posts will stay in place and will publish once the channel is active again.
