Nuelink MCP FAQs
Do I need a separate API key for each AI assistant?
No, you can use the same API key across Claude, ChatGPT, Cursor, Manus, Codex, and any other MCP-compatible assistant. That said, if you want to be able to revoke access for one assistant without affecting the others, you can generate a separate key for each.
Can the MCP post to specific channels only?
Not directly. The MCP server uses your collection's settings to decide which channels receive a post. If you want a post to go to a different set of channels, post it to a different collection that's set up for those channels.
What time zone are scheduled posts in?
Scheduled posts use the brand's time zone (set in your Nuelink dashboard), not your computer's local time. If you say "Friday at 9 am," the assistant uses 9 am Friday in whatever time zone that brand is configured for. To be safe, mention the time zone explicitly, for example, "Friday at 9 am Casablanca time."
Can I revoke access if I no longer want an assistant connected to Nuelink?
Yes. Go to Settings → API in your Nuelink dashboard, find the key you used for that assistant, and click Delete. The next time the assistant tries to call a Nuelink tool with that key, it'll get a 401 Token has been revoked response.
Will the MCP work with my team or agency brands?
Yes. Your API key inherits all the brands your Nuelink user has access to. If you're on a Business or Agency plan, or you've been added to someone else's team, the MCP server sees every brand your key can reach. Just remember, your role applies; if you have read-only access to a brand, you can see it, but can't post to it.
