How to Setup Etsy Automation to Auto-Post Your Products to Social Media
This guide shows you how to automatically turn your Etsy listings into social media posts with Nuelink. Once set up, every listing in your shop can be shared to your social channels, no manual posting needed.
Note: To follow this guide, you'll need a Nuelink account, an Etsy shop, and at least one social channel connected to Nuelink.
- Go to Automations in the left sidebar, then click Create Automation.
- Select the eCommerce tab (or search for "Etsy"), then click Create Automation on the Etsy card.
- In the Add Etsy Automation window, paste your Etsy Store Link (e.g., https://www.etsy.com/shop/YourShopName).
- Write your Post Caption. This caption is automatically applied to every new post. You have two options:
- Write it yourself using variables like {{title}}, {{link}}, {{website}}, {{website_title}}, {{website_description}}, {{description}}, {{price}}, and {{currency}}. You can write multiple variations, and Nuelink will rotate between them.
- Turn on AI captions (Beta) and write a prompt instead. AI will write a unique caption for each listing based on your instructions. Click Add Fallback Caption to set a backup caption in case the AI can't generate one.
- Enter a Post title (optional). The default is {{title}}, which uses each listing's name. This title is used on YouTube, Pinterest, and Facebook videos.
- Toggle Auto thread long captions if you want captions that are too long for Threads, X, Bluesky, or Mastodon to be split into a thread automatically.
- Choose your post format: Link Post, Image Post, Carousel Post, or Video Post. Carousel posts share several listing photos in one swipeable post, while video posts share each listing as a video.
- Decide if you want to import existing Etsy posts as well as the future ones. Leave it on to import listings already in your shop, and set the Number of Posts to Import (between 1 and 100). Turn it off to only import future listings.
- Toggle Mark the posts as draft for later review if you want posts from this automation saved as drafts, so you can review and approve them before they go out.
- Toggle Publish Immediately if you want new listings shared right away. Nuelink checks your shop hourly, publishes the latest post immediately, and queues the rest. Note: existing posts are queued, not published immediately.
- Toggle Send a follow-up comment to automatically add a comment under each post (e.g., "shop here: {{link}}"). You can use the same variables as your caption. Set a Delay so the comment is added a set number of minutes after the post is shared (e.g., 60 minutes). Keep in mind that Instagram and YouTube comments don't support images.
- Toggle Use smart conditions to filter which listings get posted:
- Keyword Condition: Choose Include or Exclude, then add keywords and hit enter. Only listings with (or without) these keywords in their titles will be added.
- Exclude Out-of-Stock Products: Skips sold-out listings automatically. Nuelink moves them to Drafts and re-adds them when they're back in stock.
- Toggle Auto-clean links to automatically remove UTM and tracking query strings from links generated by this automation. This applies to the {{link}} shortcode only.
- Choose where your posts will live:
- Leave Create a new collection for this automation to keep these posts in their own new collection.
- Uncheck it if you'd rather add the posts to one of your existing collections; you'll get to pick which one.
- Click Add Etsy Automation.
That's it, you're ready to go! Nuelink will start importing your listings. You'll see a Processing banner on your collection while your posts are being imported. Check back in a few seconds to see them.
Manage Your Collection After Setup
Your automation's posts live in a collection (a new one, or the existing one you picked) that controls where and when they go out. Posts added to the collection automatically use its channels, schedule, and recycling rules. Here's how to set it up:
- Under Collection Name, rename the collection if you'd like and tag it with a Color code for easy recognition.
- Under Default Social Channels, select the social channels where posts from this collection should be published. If you use Pinterest, choose a Pinterest Board (one board per channel). If you use YouTube, pick your YouTube Playlists.
- Set your Weekly Schedule, the days and times when posts go out. Select your days, pick a time, and click Add slots. Posts fill the next available slot. You can also click Change to adjust the timezone.
- Toggle Recycle published posts (evergreen) to keep your listings circulating automatically. Set a Cooldown (e.g., wait 4 weeks, then add it back to the queue) and a Repeat limit (e.g., forever, or a set number of times).
- Choose your Queue Behavior, where new posts land in the queue: Top of the queue (post sooner), Bottom of the queue (post later), or Random (shuffle into the schedule).
- (Optional) Click Advanced Options to Pause posting from this collection without deleting posts, or set a Timeframe limit with a start and end date for when this collection is active.
- Click Save Changes.
You're all set! Your listings will now post to your chosen channels on your schedule.
What's the difference between writing my own caption and using AI captions?
Your own caption uses the same template (with variables like {{title}} and {{price}}) for every post. AI captions write a fresh, unique caption for each listing based on your prompt. AI captions use NueAI credits.
Which post format should I choose?
It depends on your channels. Image Post works everywhere. Carousel Post is great for showing multiple listing photos on Instagram and TikTok. Video Post turns each listing into a video, perfect for Reels, TikToks, and YouTube Shorts. Link Post shares the listing as a clickable link preview.
Will my sold-out listings be posted?
Not if you turn on Exclude Out-of-Stock Products under smart conditions. Nuelink moves them to Drafts and automatically re-adds them when they're back in stock.
Can I review posts before they're published?
Yes. Turn on Mark the posts as draft for later review when setting up the automation. All posts will land in your collection's Drafts tab until you approve them.
Do I have to create a new collection for the automation?
No. Uncheck Create a new collection for this automation during setup, and you'll get to pick one of your existing collections instead. The posts will follow that collection's channels, schedule, and recycling rules.
Can I add a link in a comment instead of in the caption?
Yes! Turn on Send a follow-up comment and write something like "shop here: {{link}}". You can delay the comment by a set number of minutes after the post is shared.
My posts aren't showing up after I created the automation.
Importing can take a moment. If you see the Processing banner on your collection, wait a few seconds and refresh. If posts still don't appear, double-check that your Etsy Store Link is correct (it should look like https://www.etsy.com/shop/YourShopName).
My posts are stuck in the queue and never publish.
Your collection needs a Weekly Schedule. Open the collection's Settings tab, add days and time slots under Weekly Schedule, and click Save Changes. Posts fill the next available slot.
Some of my listings were skipped.
Check your smart conditions. If you set keyword Include/Exclude rules or turned on Exclude Out-of-Stock Products, listings that don't match are skipped or moved to Drafts.
My follow-up comment didn't include an image.
Instagram and YouTube comments don't support images. Use text and variables (like {{link}}) for comments on those platforms.
