How to Setup Pocket to Auto-Post to your Social Media
Make sure you're logged in to your Nuelink account and connected to your social media channels. If not, you can connect it by following these steps, and let's set up your Pocket automation to auto-post on your social media.
Note: Mozilla shut down Pocket in July 2025, so the Pocket automation no longer works. To keep sharing saved articles, use a read-later app that offers an RSS feed and set up an RSS Feed automation instead.
Now, let’s get started with setting up your Pocket automation.
1. First, click on Automations on the navbar on the left side of the screen.
2. Click on Add Automation button on the top right of the screen.
3. Scroll down until you find Pocket, and then click on Add Automation.
4. Select a Collection to add posts from this automation to.
5. Click on Add Pocket Automation and you are done.
You can also check and uncheck other features as you see fit:
⭐️ Adjust the variables in the Post Description or rewrite it altogether.
⭐️ Check Import my Favourite Articles only if you want to import only your favourite articles.
⭐️ Mark posts from this automation as Drafts to review later.
This is it for this tutorial, please check our Help Center for further tutorials. We have many videos and articles on how you can use Nuelink to its fullest.
