How to Set Up Squarespace to Auto-Post your Blogs to Social Media
Make sure you're logged in to your Nuelink account and connected to your social media channels. If not, you can do so by following these steps, and let's set up your Squarespace Shop automation to auto-post on your social media.
Now, let’s get started with setting up your Squarespace Shop automation.
1. First, click on Automations in the navbar on the left side of the screen.
2. Then, click on the Add Automation button at the top right of the screen.
3. Scroll down until you find Squarespace Blog, and then click on Add Automation.
4. Copy and paste your Squarespace Blog website link here.
5. Click on Add Squarespace Blog Automation, and you are done.
✅ Your products will be added automatically to your collection, both existing products and the ones you add in the future.
📕 We check your Squarespace Shop every 24 hours for new products and add them to your collection.
You can also check and uncheck these options as you see fit:
⭐️  Adjust the variables in the Post Description or rewrite it altogether.
⭐️ Uncheck Create a New Collection for this Automation, and select an existing collection instead.
⭐️ Uncheck Import existing podcasts as well as future ones if you want to import social media posts for only future podcast episodes.
⭐️ Mark posts from this automation as Drafts to review later.
⭐️ Click here to Import Posts as Images. If you want to share as image posts instead of link posts.
This is it for this tutorial; please check our Help Center for further tutorials. We have many videos and articles on how you can use Nuelink to its fullest.
