How to Create and Schedule a LinkedIn PDF Carousel Post on Nuelink?
This guide walks you through creating and scheduling a LinkedIn PDF (Document) carousel post in Nuelink. You'll learn what document posts are, what LinkedIn requires, and how to publish one in just a few steps.
Note: To follow this guide, you'll need a Nuelink account with your LinkedIn Profile or LinkedIn Company Page already connected. If you haven't connected your LinkedIn account yet, follow our guide on connecting social media accounts first. Document posts are only supported on LinkedIn Profiles and LinkedIn Company Pages, with a maximum of 10 pages per document.
Video Tutorial:
Here’s a video walkthrough of the process of creating and scheduling any Multi-Image and video post on Nuelink:
About LinkedIn Document Posts
What is a Document (PDF) Post?
A LinkedIn document post lets you share a PDF or PowerPoint file as a swipeable carousel in the feed. Each page of the document appears as a single "slide" that viewers can flip through. LinkedIn document carousels support up to 10 pages and adjust to different sizes for a clean, polished look.
Why Create a LinkedIn Document Carousel Post?
Document carousels are one of the most engaging formats on LinkedIn. They're perfect for sharing step-by-step guides, statistics, infographics, mini case studies, and educational content your audience will want to save and revisit. These posts are powerful for driving engagement, boosting brand awareness, and building authority on the platform.
LinkedIn Document Post Requirements
Before you upload, make sure your file meets LinkedIn's requirements:
Requirement Details
Supported on LinkedIn Profiles and LinkedIn Company Pages
Maximum pages 10 pages per document
File format PDF
Maximum file size 100 MB
Recommended page size 1080 x 1350 px (portrait) or 1200 x 1200 px (square)
⚠️ Important: Document posts are exclusive to LinkedIn. If you select another platform in the same post, the document upload won't work for that channel.
1. Open the Post Creator
Go to your Nuelink account and click Create Post in the top-left of the navigation bar (you'll also find this button at the top of your Queue and inside any Collection). Then select Post from the top bar.
2. Select Your Collection
Choose the Collection where you'd like to add your document post.
ℹ️ What's a Collection? A Collection is like a folder for your social media posts. It helps you organize and schedule content by theme or campaign, with its own default channels and posting time slots. Learn more about Collections here.
3. Select Your LinkedIn Channel
Pick the LinkedIn Profile or LinkedIn Company Page you want to post to. If you've already added these channels to your Collection, they'll be selected automatically.
💡 Tip: We highly recommend adding your channels to your Collection so you don't have to pick them every time.
⚠️ Document uploads only work for LinkedIn Profiles and LinkedIn Company Pages, not for other platforms.
4. Upload Your Document
Click Add a Document and upload your PDF file.
Once your document is uploaded, you can:
  • Preview how the carousel will look in the Post Preview on the right.
  • Use the arrows to swipe through each page.
  • Replace or remove the document if you need to make changes.
  • Change your PDF name.
⚠️ If you see an error, double-check your file against the Document Post Requirements shown under your Post Preview.
5. Write Your Caption (and Try NueAI)
Click Caption to add your post description. Want to spice things up? Click the NueAI Assistant for help.
NueAI can:
  • Generate Hashtags: Create hashtags that match your caption.
  • Rephrase: Polish and improve your wording.
  • Make it engaging: Add more energy and interaction.
  • Make it Formal: Shift the tone to professional.
  • Expand it: Turn a short line into a full paragraph.
  • Shorten it: Summarize while keeping the main idea.
  • Make it a Thread: Break your caption into a multi-section thread.
  • Use Your Own Prompt, Type a custom instruction, and let NueAI write for you.
You can also enhance your caption with:
  • Emoji Picker: Add emojis that fit your message.
  • Change Text Direction: Switch between left-to-right and right-to-left.
  • Hashtag Manager: Generate hashtags or pick from saved groups.
  • Shortcodes: Insert dynamic snippets. Learn more about Shortcodes here.
6. Explore Advanced Options
Click More Options and scroll down to access additional features. For LinkedIn document posts, you can:
  • Send a follow-up comment: Add a comment to your post automatically after it publishes. You can use NueAI to write or improve it.
7. Choose How to Schedule Your Post
Pick one of these scheduling options:
  • Add to Queue: Adds your post to the end of your Collection's queue.
  • Share Next: Schedules your post for the next available slot in the queue.
  • Save as Draft: Saves your post for later editing (won't be added to the Queue).
  • Post Now: Publishes your post immediately (skips the Queue).
  • Schedule Once: Pick a specific date and time. This post won't repeat, even if Evergreen is enabled for your Collection.
You're all set, your LinkedIn document carousel is ready to go! 🎉
Where to Find Your Post After Scheduling
Once you've scheduled your post, you'll find it in your Collection's Queue.
Queue editing options:
  • View and preview your scheduled post.
  • Post Now, Publish immediately (skips your queue order).
  • Edit: Make changes to your post.
  • Delete, Permanently remove the post.
If you saved your post as a draft, you'll find it under the Drafts tab inside your Collection.
Draft editing options:
  • View and preview your draft.
  • Add to Queue, Move your draft into the Queue.
  • Edit, Continue editing.
  • Three-dot menu:
    • Post Now, Publish immediately.
    • Move, Move the post to another Collection.
    • Duplicate: Make a copy of the draft.
    • Delete, Permanently remove the draft.
What's the maximum number of pages in a LinkedIn document post?
LinkedIn allows up to 10 pages per document, which displays as a 10-slide carousel.
Can I post a document carousel to other platforms like Instagram or Facebook?
No. LinkedIn document posts are exclusive to LinkedIn Profiles and Company Pages. For Instagram carousels, you'd upload individual images instead.
Can I bulk-upload document carousels in Nuelink?
Yes! Nuelink supports bulk uploading of multi-image, video, and document content. Learn how to bulk-upload posts here.
Can I change the time of a post that's already in my Queue?
Yes. Open your Queue, click Edit on the post, then click Schedule to pick a new date and time.
What file formats does LinkedIn support for document posts?
LinkedIn supports PDF files. If your content is in PowerPoint or another format, convert it to PDF before uploading.
My LinkedIn document post didn't publish after scheduling.
Publishing failures are usually caused by a file that exceeds LinkedIn's limits (more than 10 pages or over 100 MB) or a format issue. Double-check your file against the requirements, then try rescheduling. If you're still stuck, contact Nuelink support.
I can't see the "Add a Document" option.
Make sure you've selected a LinkedIn Profile or LinkedIn Company Page as your channel. The document upload option only appears when LinkedIn is the only platform selected; it won't show up if you've also picked Instagram, Facebook, or another channel.
My LinkedIn account shows a "restricted" error when posting.
LinkedIn may have temporarily restricted your account. Common reasons include unusual activity, profile name violations, or compromised accounts. Check LinkedIn's restriction help page for details, then reconnect your account in Nuelink once the restriction is lifted.
My document looks blurry or low-quality in the preview.
Export your PDF at a higher resolution before uploading. We recommend a page size of 1080 x 1350 px (portrait) or 1200 x 1200 px (square) for the sharpest results.
Still need help? Check our Help Center for more tutorials or contact our support team. We're happy to help!
