How to Create a Post on Nuelink
Nuelink is designed to simplify content creation and social media management for everyone. In this guide, we will walk you through making a post via Nuelink.
Before we begin, please make certain that you are logged in to your Nuelink account and that your social media profiles are connected. If not, you can follow these steps to connect them. Let's now dive into creating a post on Nuelink.
Nuelink facilitates the creation of a variety of posts.
Select General, Carousels.
To learn more about the process of creating different types of posts, you can refer to the following articles:
What Is a  Post?
A  post is a type of post that can be shared across all of your social media platforms simultaneously. As long as you adhere to each platform's specifications, you can create a single post to share on up to 12 platforms via Nuelink. Before you create a post, please make sure that all of your socials are connected to Nuelink.
Let’s Create a Post
  1. First, click on the Create Post button.
  2. Select post type.
  3. Select your Collection, you can skip this step if you are creating your post in a collection. You can learn more about collections by clicking Here.
  4. Click on Social Channels, and select the social profiles you wish your post to be added to.
  5. Add your media.
  6. Check the post preview.
  7. Add post title.
  8. Add your Caption.
  9. Use NueAI Assistant.
  10. Caption options.
  11. Customize caption per platform.
  12. Explore more options.
  13. Use Automations.
  14. Scheduling options.
  15. Find your post in drafts.
  16. Find your post in the queue.
  17. Final published post on socials.
Posts FAQ & Troubleshooting:
Why did my Post not get published after I scheduled it?
If you encounter any publishing errors, it is most likely due to the video duration, format, or size.
Please make sure your posts meet each Platform's requirements.
Can I create a one-off post?
On Nuelink, you can create a one-off post by simply creating a collection for the one-off posts. You can set a scheduled time or choose to post it immediately.
Why are my posts 'processing' after I publish them?
Once you publish a post, it may take some time to be posted on socials, please remain patient until your post is published.
What is the maximum number of images/videos for carousels on each social channel?
Currently, Instagram, Facebook, and Telegram only allow a maximum size of 10 multi-images and videos per carousel, and Twitter allows a maximum of 4 multi-images and videos per tweet. LinkedIn and TikTok support up to 10 images only in a single carousel post. Pinterest on the other hand allows 5 images max per pin carousel.
Can I bulk-upload carousels and video posts in Nuelink?
Yes, on Nuelink you can bulk upload multiple types of content from texts, and images to videos and carousels. Learn more about bulk uploads and watch how to do it here.
Can I change the time of posting for a post that is already in the Queue?
Luckily, you can. Click on Edit at the bottom of the post then click on Schedule Once. You can select an exact date for your post. This update will move your post out of your collection’s queue schedule.
Can I copy a post to other collections?
Yes, you can duplicate a post to another collection, or you can move it from one collection to another.
What is the maximum size allowed for videos?
Currently, the maximum size limit for videos is 100MB. However, the team is working on the ability to compress videos so you can post videos larger than 100MB.
Can I post a Facebook or Instagram story?
Yes, you can schedule Image stories via Nuelink to be posted on your Facebook and Instagram stories.
Can I add a background to the text on Facebook?
Yes, you can add a text post from the post editor. Make sure you select the Facebook preview and use the post template button (next to the emoji picker) to select a background.
